Unity Replication Monitor "RED X"
Jul 22nd, 2008
On my primary Unity server, replication is not working. Currently my
seconday server is acting as primary and I would like to failback to primary. However I
notice the red X on Replication with the following error:
Server: CHS-UNITY, Database UnityDb : ODBC Error:Could not change the Publisher because
the subscription has been dropped. Use sp_subscription_cleanup to clean up the triggers.
Any way to fix this without rebuilding my Unity server? We are running Unity 4.2(1)
thfergus Tue, 07/22/2008 - 06:24
  • Cisco Employee,
Ensure the MSSQLSERVER and SQLSERVERAGENT services are running under the correct account. The account must be a domain account and must:
•Have the right to log on as a service.
•Be a member of the local Administrators group.
Check the secondary server name on the unitydb through query analyzer with "select
@@servername account. If is different
It was different, follow the procedure below to change to correct name :
- stop Unity
- stop SQLSERVERAGENT
- open Query Analyzer
- use the following commands:
sp_dropserver '', 'droplogins'
sp_addserver '', 'local'
reboot the secondary server
- open Query Analyzer and use 'select @@servername' to confirm the correct secondary servername is registered
- rerun Failover Configuration Wizard
