Measurement Based CAC - Dial-peer Selection - Help
Jul 22nd, 2008
I have a very interesting case of a customer's router(gateway)across a satellite link
The integrity of the link varies based on multiple satellite factors.
I pre-configured two dial-peers using g729A, one with the default 20 bytes size and the other with 60 bytes.
How can I select dial-peers based of the performance of the link?
I know that "monitor probes can test the link", but my question refer to the tool that can differentiate and prefer the results of the probe and choose one dial-peer based on performance.
By selecting the proper dial-peer I can improve the quality of the voice.
Something similar to floating static routing using metrics based on BW,Delay, reliability of the link.
I will really appreciate your inputs
Thank you, all
