CIFS access VIA SSL VPN Portal
Jul 22nd, 2008
I have disable netbios on my servers. I am also trying to use CIFS in the SSL portal. it apprears that the CIFS is using port tcp/139. can we change that to use SMB on tcp 445
Overall Rating: 3 (1 ratings)
steavg Wed, 07/23/2008 - 11:09
ASA WEBVPN only supports CIFS on port 139.
hope this helps,
cheers
stefan
