Setting up HSRP for redundant Gateway configuration..
Jul 22nd, 2008
I am trying to get some backup for my existing Lab Gateway (7200). I have another 7200 that I want to use to setup as the backup Router. I have never done this so I need some help. How do I connect the two first of all and then how do I set it up. I need urgent help with this. My current Gateway keeps going down every once in a while..
Giuseppe Larosa Tue, 07/22/2008 - 07:13
  • Hall of Fame,
    Founding Member
Today another post on the same subject has been opened in the same forum
look at the following link
http://www.cisco.com/en/US/docs/ios/ipapp/configuration/guide/ipapp_hsrp_ps6350_TSD_Products_Configuration_Guide_Chapter.html
You need to have L2 connectivity on LAN interface to provide a virtual default gateway to the clients. Then the second router must access the same outer network as the first one using the same protocols.
Hope to help
Giuseppe
