how to update the cisco Works certificate?
Jul 22nd, 2008
The certificate of Cisco Works expired The 11th of June. I want to know how to update it?. I attached a copy of the certificate.
Overall Rating: 5 (1 ratings)
Joe Clarke Wed, 07/23/2008 - 09:05
Do the following:
* net stop crmdmgtd
* cd NMSROOT\MDC\Apache\conf\ssl
* del server.*
* NMSROOT\bin\perl -disable
* NMSROOT\bin\perl -enable
This last step will prompt you to enter all of your cert info. Once that is done, you have a choice. If you want to run with SSL enabled, you will need to re-run:
If you do not want to run with SSL enabled, then simply rest5art dmgtd:
net start crmdmgtd
Note: NMSROOT is the path into which you have installed CiscoWorks. By default, this is C:\PROGRA~1\CSCOpx.
