Optimal choice for a stackable switch (and what to look for)
Jul 22nd, 2008
I have a 100 user network connecting to a 20Mbps private IP backbone. I need to select a router and a switch. For this conversation, lets focus on the switch.
Which Gigbit capable stackable switch would you recommend ?
Joseph W. Doherty Tue, 07/22/2008 - 08:36
Besides the 3750-E, there's also the original 3750 series. Both 3750 series can offer triple speed Ethernet interfaces. The -E series can provide more performance, for routine user hosts, you might not need the addtional performance.
BTW: Both 3750 series can also route. Depending on your needs with the 20 Mbps, you might not need a separate router.
