IP Communicator
Jul 22nd, 2008
I am trying to set up IP Communicator to make outbound calls.
I have it set with and extension and can receive inbound calls from an outside line but will not make an outbound calls.
i am pretty new to this so any helpful hints or pointing me in the right direction (guides) would be great!
Overall Rating: 5 (1 ratings)
komputerguy Tue, 07/22/2008 - 09:27
Make sure the extension assigned is in the right partition and CSS.
Jaime Valencia Tue, 07/22/2008 - 10:25
what happens??
do you hear "your call cannot be completed as dialed..."?
fast busy?
you're not able to dial the whole number?
javalenc
if this helps, please rate
