PPPoE Server on ISR
Jul 22nd, 2008
Hello, friends,
I'm trying to implement a solution with metro connections between two remote points and a central one using metro ethernet. I was thinking about deploying two 1841 on the edges and one 2801 on the core.
My question is: what is the minimum platform and IOS version/feature set that is necessary to run a real PPPoE SERVER and still considering this scenario? My servers will run on the edges.
I appreciate!
Giuseppe Larosa Tue, 07/29/2008 - 07:26
  • Hall of Fame,
    Founding Member
Hello Mauricio,
to answer your question you should use the feature navigator inside CCO
www.cisco.com/go/fn
use search by feature set
type PPPoE server
specify 1841 as platform
and you get
12.4(21) main release advanced ip services, advanced enterprise services,
that require 192 MB RAM 64 MB flash
advanced security, broadband, enterprise base, enterprise services
that require 128 MB RAM 32 MB flash
Hope to help
Giuseppe
