Inter VLAN Routing and Cisco 1711
Answered Question
Jul 22nd, 2008
I am trying to get inter VLAN routing working on a Cisco 1711 switch with the 4 port switch WIC but it is not working. I think its something simple but I can figure it out. I cant ping from the computers to each sub interface. i.e. I cant ping FastEthernet 0.10 IP address of 10.1.10.1 from a laptop plugged into FastEthernet 3. The laptop has an ip of 10.1.10.2 and is using 10.1.10.1 as its default gateway. Below is a copy of my config.
Router#show conf
Using 1045 out of 29688 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
archive
log config
hidekeys
interface FastEthernet0
no ip address
duplex auto
speed auto
interface FastEthernet0.10
encapsulation dot1Q 10
ip address 10.1.10.1 255.255.255.0
interface FastEthernet0.20
encapsulation dot1Q 20
ip address 10.1.20.1 255.255.255.0
interface FastEthernet1
switchport mode trunk
interface FastEthernet2
interface FastEthernet3
switchport access vlan 10
interface FastEthernet4
switchport access vlan 20
interface Vlan1
no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line vty 0 4
end
Correct Answer by lgijssel about 8 years 9 months ago
O, I assumed it would.
In that case, thank you for rating my post;-)
Overall Rating: 5 (1 ratings)
Edison Ortiz Tue, 07/22/2008 - 10:37
  • Hall of Fame,
    Founding Member
That setup won't work.
Try this:
Remove the interfaces
no interface FastEthernet0.10
no interface FastEthernet0.20
Verify the vlans are created in Layer2
sh vlan-switch
If they don't exist
vlan database
vlan 10
vlan 20
exit
Create the Layer3 interfaces
interface vlan 10
no shutdown
interface vlan 20
no shutdown
Try pinging now.
HTH,
__
Edison.
Please rate helpful posts
lgijssel Tue, 07/22/2008 - 10:46
  • Red, 2250 points or more
You likely have to define the vlans in the vtp database:
#vlan database
vlan 10 name vl10
vlan 20 name vl20
exit
If this has not been done, the vlans will not become active.
regards,
Leo
Correct Answer
lgijssel Tue, 07/22/2008 - 12:00
