Syslog
Jul 22nd, 2008
How do i enable my RME to receive syslog mesaages from devices.
I have configured all the devices in my network to send syslog messages to RME,but each time i make a change on my box in message is sent.
Why did i go wrong,please let me know.
Thanks for your reply.
Joe Clarke Tue, 07/22/2008 - 11:36
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Nothing needs to be done in RME. You need to make sure your devices are sending messages with a facility of local7 to the RME server.If the devices are not sending messages, then you need to double-check your config. In general, this is all you need:
logging 10.1.1.1
logging trap info
logging facility local7
sameoj1881 Tue, 07/22/2008 - 11:42
Where do i get to check this.
Joe Clarke Tue, 07/22/2008 - 11:45
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Do a show run on the device. You can also see this by doing a show logg.
sameoj1881 Fri, 07/25/2008 - 03:21
Do I need to configure all the three statements or just the first statement will do the work.
Please reply,thanks
Joe Clarke Fri, 07/25/2008 - 08:27
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Technically just the first since the other two are default. As I said, do show logg to see what the current syslog parameters are.
