07-22-2008 12:34 PM - edited 03-18-2019 09:21 PM
While Unity is playing a call handler greeting, if the caller inputs a value that Unity does nto understand, Unity plays the Default Opening greeting.
How do I disable this behavior? I vaguely remember that this could be done in the Advance Setting Tool but I don't recall the option.
Solved! Go to Solution.
07-22-2008 12:41 PM
Hi Jeffrey,
This is from Unity Design Engineer Jeff Lindborg;
"You can expose the error greeting in the SA interface using the Advanced Settings tool. You can also use BulkEdit to do the for all your handlers and subscribers if you like - there's a special option called "loop back to self" for the error greeting option that's made just for this type of thing." Jeff
Hope this helps!
Rob
07-22-2008 12:41 PM
Hi Jeffrey,
Hope this helps!
Rob
07-22-2008 01:17 PM
Thanks, now I remember what to look for...
http://www.ciscounitytools.com/Applications/Audio%20Text%20Applications%20in%20Unity.doc.
Error Greetings
Easily the most misunderstood and overlooked item by Unity administrators. The first problem is by default this greeting doesn't even show up in the SA interface at all so folks don't even know it's there. And if they do, folks often don't understand what it does, exactly.
Step one is to expose it in the SA. This can be done using the Advanced Settings tool found in the âAdministration Toolsâ section of the Tools Depot. The option you want is âExpose the error greeting for subscribers on the SAâ - just set it's value to â1â and the âErrorâ greeting option will appear in the greetings drop down list for all subscribers and call handlers in the SA. Frankly I think this should be on by default but in early versions of Unity we got so many calls from folks wanting to know what this error in the SA was about the decision was made to hide it in the interface since at that time the need to customize the greeting's behavior was very limited. This is probably one of those decisions that needs to be revisited now that the product's matured some and the smart, good looking, savvy folks who are out there selling and installing it are ready to handle some additional complexity.
