AP1242G Antennas
Probably a silly question, but here goes:
We ordered five AIR-AP1242G-A-K9 Access Points under the impression that they had 4 antenna connectors; Obviously we were somewhat misinformed as it only has 2. We ordered antennas that have 2 antennas in each unit, therefore 2 connectors, and our goal is to connect 2 antennas to each AP - What are our (if any) solutions here?
I'm assuming connecting one antenna from each unit would severely degrade signal quality.
izackvail Tue, 07/22/2008 - 14:44
  • Bronze, 100 points or more
The 1242AG access points have 4 antennas. 2 for the A radio and 2 for the G radio. The 1242G only have 2 antenna because there is no A radio.
You definitely want 2 antennas for each AP.
feng-chen Mon, 09/08/2008 - 10:40
I got the 1240AG, but the antenna came with the package is AIR-ANTM4050V-R which only have two connectors??
Sushil Kumar Katre Tue, 07/22/2008 - 20:24
  • Gold, 750 points or more
There are two models in 1240 APs.
One of which is AG and the other is G only.
AG you'll have 4 connectors two for A and two for G.
G you'll just have 2 connectors.
However I don't see an option to make two different antennas with 2 individual connectors get connected on the AP.
I'll suggest you to open this post in wireless forum.
-> Sushil
