Fax from ATA to ATA using H323
Jul 22nd, 2008
Hello!
I have an H323 gateway and want to set it up where I can fax from one fax machine connected to an ATA to another fax machine connected to a separate ATA. Can this be done and if so, what do I need to add or remove from my configuration? I have attached the configuration of the ATAs. I know its missing from below but I do have the h323 interface configuration on the gateway.
voice service voip
fax protocol t38 ls-redundancy 2 hs-redundancy 0 fallback none
h323
no h225 timeout keepalive
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class h323 1
h225 timeout tcp establish 3
application
global
service alternate default
dial-peer voice 10000 voip
destination-pattern 9295
progress_ind setup enable 3
modem passthrough nse codec g711ulaw
voice-class codec 1
session target ipv4:172.24.86.21
incoming called-number 9295
dtmf-relay h245-alphanumeric
fax rate disable
no vad
dial-peer voice 15172 voip
description ** Inbound DIDs to ATA **
destination-pattern 5172
session target ipv4:172.24.86.27
incoming called-number 5172
fax rate disable
no vad
no dial-peer outbound status-check pots
gateway
timer receive-rtp 1200
Michael Hanes Mon, 07/28/2008 - 21:12
I checked your configurations and they are fine. Assuming that you have call routing configured correctly and you match the correct dial-peers on the H.323 gateway you should be able to send and receive fax calls between these three devices.
David
