Overlap Dialing
Jul 22nd, 2008
Hi NetPro,
I have a 3845 running as PSTN gateway with 3 ISDN PRI ports. SIP trunks connect this gateway to a few CME's.
Outgoing calls are established not quick enough(for some users) as it takes aboiut 8 seconds to call a mobile phone. I find a command 'isdn overlap-reeiving' in the doc, but is it used for incoming calls? How can I configure overlap dialing for outgoing calls to fasten the connections?
Thanks in advance.
Chuan Liu Mon, 07/28/2008 - 13:32
Hi Ursula,
Thank you very much for the reponse.
I do not have a CallManager. I am looking for the configurations in cme or the PSTN gateway router.
