deepa.muralidharan Wed, 07/23/2008 - 00:22
Both L2 & L3 VLAN are created & I do see the vlan as "active" in "Sh vlan " output.
lgijssel Wed, 07/23/2008 - 00:30
  • Red, 2250 points or more
Did you actually perform the config below?
Router# vlan database
Router(vlan)# vlan vlan_ID
Router(vlan)# exit
Your description is typical for having not, so please check the link I sent you and verify that the "show interface vlan xx" reports up/up as the status.
regards,
Leo
deepa.muralidharan Wed, 07/23/2008 - 00:38
Leo,
I have created it exactly the way mentioned. No change seen.
Also, when I see the vlan status as "active" in "sh vlan" output; doesn't it mean that the L2 status is up ?
Deepa
lgijssel Wed, 07/23/2008 - 01:05
I would think so, yes but that does not explain you seeing what you wrote in your second post: The output of sh int vlan gives : Vlan is down, line protocol is down
That vlan can only be down when there are no ports (including trunks) that forward this vlan. The only situation that can possibly explain that would be when there is only one port that carries the vlan and this port is not connected.
This means you may have connected to the wrong port; a non-existing vlan seemed like a more plausible cause.
regards,
Leo
