871W in Universal Client Mode Bridging Issue
Jul 22nd, 2008
I have a 1242 Access Point as root and a 871W Router as a non-root bridge (Diagram attached). I have a laptop connected to Fa 0 of the 871W router.
* I am able to ping from the AP to the Router and vice versa
* I am also able to ping from the router to the laptop and vice versa
* But I am not able to ping from the laptop to the AP
All bridging commands seem to be fine. Even tried adding route commands, but none seem to work. All suggestion are welcome, Thanks.
Please find the configuration below:
Configuration on Root AP:
hostname ap
enable secret 5 XX
ip subnet-zero
no aaa new-model
dot11 ssid Cisco
authentication open
username Cisco password xxx
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid Cisco
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
infrastructure-client
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
station-role root
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
hold-queue 160 in
interface BVI1
ip address 192.168.1.10 255.255.255.0
no ip route-cache
ip default-gateway 192.168.1.254
ip http server
no ip http secure-server
ip http help-path
control-plane
bridge 1 route ip
line con 0
line vty 0 4
login local
End
Configuration on non-root 871W:
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
dot11 ssid Cisco
authentication open
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.20
ip dhcp pool ADSL_LAN_POOL
network 192.168.1.0 255.255.255.0
default-router 192.168.1.20
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
archive
log config
hidekeys
bridge irb
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
no ip address
shutdown
duplex auto
speed auto
no ip address
ssid Cisco
station-role non-root
bridge-group 1
interface Vlan1
no ip address
ip tcp adjust-mss 1452
bridge-group 1
interface BVI1
ip address 192.168.1.20 255.255.255.0
no ip route-cache cef
no ip route-cache
ip default-gateway 192.168.1.10
ip forward-protocol nd
no ip http server
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
no modem enable
line aux 0
line vty 0 4
login
scheduler max-task-time 5000
end
Overall Rating: 2 (1 ratings)
jennyjohn Mon, 09/01/2008 - 22:30
When station-role non-root is used, the router works in Universal Client Mode and it works in Layer 3. Hence Bridge-group commands on Dot11radio interface & Vlan 1 interface wouldn't work. Both interfaces have to be given an IP address and nat overloading needs to be done on the router to map the many router client IP address to the single dot11 IP address connecting it to the main network.
for more details:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40.2cc1907b
ekonishijunior Mon, 05/13/2013 - 19:07
I have the 871w router but I can´t change the station-role mode to non-root, I receive the following message:
can not disable station-role
Somebody know why i cannot change to station-role non-root?
thanks
Scott Fella Mon, 05/13/2013 - 19:09
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Do you have that option when you issue a station-role ?
Scott
Help out other by using the rating system and marking answered questions as "Answered"
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
