Reg: C2948G-GE-TX
Jul 22nd, 2008
Hi Guys,
I have a 2948g-ge-tx switch. It says the supervisor module has failed. I dont have physical access to the switch and form the web I found out that it is a fixed configuraiton switch.
show module
Mod Slot Ports Module-Type Model Sub Status
1 1 0 Switching Supervisor WS-X2948G-GE-TX no faulty
2 1 52 10/100/1000 Ethernet WS-C2948G-GE-TX no ok
It is operating normally. What effect will it have if I do not replace it. The next question is how to replace it. Do i have to replace the whole switch or there is a supervisor module on the switch which I have to replace may be inside the switch. From outside I can see is only a 48 port switch.
lgijssel Tue, 07/22/2008 - 22:51
It's a fixed-configuration switch so you are unlikely to be able to replace the supervisor inside of it. As far as I know, these devices are no longer supported by Cisco either.
Considering the age of the device, buying something new not would be unappropriate.;-) If you are unwilling to spend money on that, your best bet would be to achieve one from the refurbished or second-hand circuit.
glen.grant Wed, 07/23/2008 - 05:55
You have to replace the whole switch . Without looking at the logs to see what the matter is it is hard to say. Sometimes these boxes will get a sdram error and powering it all the way off and back on will fix them . But you also risk the possibility that it might not reboot due to whatever error it is seeing .
