Mesh networking
Jul 22nd, 2008
Equipments being used:
1) Cisco 2106 WLAN controller
2) Cisco 1131AG access points (LWAPP mode)
3) Cisco catalyst 2950 switch
My setup is as follows:
My access point is registered with the WLAN controller via the switch. When i try to change the mode of the access point to bridge. It does not accept the change. My aim is to create a mesh network using 1131AG access points.So my question is:
Can I setup a mesh network using Cisco 1131AG access point in LWAPP mode or do i need to change them to autonomous mode?
Any documentations or comments will be helpful.
Thanks in advance.
Sri
Overall Rating: 3.8 (3 ratings)
Siva Rama Krish... Mon, 07/28/2008 - 02:50
Hi Sri
You need to upgrade your ios to mesh ios which is available in cisco site
you can connect up to 4 ap's ads mesh access point
sdeva1986 Mon, 07/28/2008 - 12:27
Thank You for the help
Now, i can finally setup my mesh network :D
dennischolmes Tue, 08/12/2008 - 11:53
The mesh trains are due to reconverge shortly so you will have all the 5.1x features available as well.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
