Agent goes to Not ready State
Jul 22nd, 2008
I have use IPCC ver:4.0(5) SR01ES09_Build095.
We have encountered that our cisco agents automatically change state and it will goes from log-in state to Not ready state.
what was the solution where i have to check the logs.
regards
Salman
Abdulbaseer Mohammed Wed, 07/23/2008 - 00:13
  • Silver, 250 points or more
This usually happens when the call is offered and the agent did not pickup then they will be placed into not ready state. you can check the ipcc logs but also check your agent, queue and script settings.
Good luck.
Chris Deren Wed, 07/23/2008 - 05:51
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Do the phones ring? If not, ensure that the CSS assigned to the calling devices has access to the parition of the agent's DN in CallManager.
The only time an agent can automatically transition from Ready to Not ready is when ring no answer kicks in becuse an agent did not pick up a call.
Chris
salman-ahmad Wed, 07/23/2008 - 21:36
Yes i understand this but the thing is that this will work. Call will have to go to Not ready state as it did but for few days i encountered that different user suddenly logged off and they have to login again.
Do you need any logs to understand any thing
regards,
Salman
Anthony.Lotito Thu, 07/31/2008 - 09:19
My agents have also experienced this. No call is presented to them but they go Not Ready as if RONA was envoked.
We are investigating the CTI ToolKit Agent Desktop as the culprit. We are using CTI ToolKit Agent Desktop 7.2.09816.4 and running 7.2(4) on the CTI OS Server.
Any insight to this issue would be great.
Thank you
david.macias Thu, 07/31/2008 - 09:59
  • Blue, 1500 points or more
I've never seen this, what does the cti svr logs show? Anything in the router log viewer?
david
