Disk Array Partitioning for Unity
Jul 22nd, 2008
Cannot dig into how to format ECS1 server RAID-1 Array of 160 Gb in size for
Unity 4.2(1) for voicemail configuration with Exchange 2003 (on-box) w/o failover.
Thinking about 20 Gb for system partition (OS, MSDE, CUSPA Applications) and the other,
140 Gb, for Unity program files and recordings. Would this be appropriate ? Any comment ?
Overall Rating: 4 (1 ratings)
tim.giles Tue, 07/22/2008 - 23:53
  • Silver, 250 points or more
These seems like sufficient enough sizes for the arrays.
I can't find any Cisco recommendations for the ratio's of the sizes on each partition but this will work fine.
Please rate post....
Just found a document saying a 12GB partition for the OS is recommended so your 20GB will be plenty big enough.
