PIX 506 to Cisco 2800 IPsec VPN, no shared keys howto.
Jul 22nd, 2008
Hello good morning ! Well let's see . . . I have to do a IPSec VPN from a on-production PIX506 to an on-production 2800 VPN concentrator, but it's a kind of tunnel that is not using pre-shared keys to AUTH. It's the kind of tunnel that uses only a determined public IP to connect to each other side of the tunnel. Now, do you know how to configure the pix properly to get this running ? I can't find any document that explains how to a tunnel without a pre-shared key or other kind of auth.
On the Cisco 2800 we already have 3 tunnels working that way and the config look like this:
crypto map SDM_CMAP_1 3 ipsec-isakmp
description mycryptomap
set peer xx.xxx.xx.115
set security-association lifetime seconds 86400
set transform-set ESP-3DES-SHA1
match address 105
Nothing more a part of the transform set and few low level config is done to get the tunnel working, so any idea on how to connect there with the PIX ?
a.alekseev Tue, 07/22/2008 - 23:44
  • Gold, 750 points or more
you have the key or cerificate
show your crypto iskmp policy
godzilla0 Wed, 07/23/2008 - 00:04
Those cryptomaps are not taking any of the isakmp policy. The isakmp policy show 3des and pre-shared keys but that is for easy VPN customers. Those 3 tunnels are not using those policies
