Cisco Unified Personal Communicator IM feature
Jul 22nd, 2008
Can I use Cisco Unified Personal Communicator as Instant Messanger feature? What equipment should I use? Is it enough CCM? Or I should buy some additional devices?
Overall Rating: 3 (1 ratings)
Ayodeji Okanlawon Wed, 07/23/2008 - 02:47
Yes you can use CUPC for IM.
You will need the follwoing devices
1. CCM5.x or 6.x
2. CUPS..Cisco Unfied presence server
3. CUPC software
4. You then need to configure your CCM and Presence server to work with CUPC
NB: You will need to purchase the required licenses for all of the devices listed above.
webstd.design Wed, 07/23/2008 - 03:55
Are you sure that "Cisco Unfied presence server" is the right name? can you give me the hyperlink ?
