Build a IPCC lab to learn
Jul 23rd, 2008
have a friend who likes to build a small lab to learn on IPCC express etc all HW and SW.
I would appreciate any help in finding the BOM and approximate cost, how to get it etc.
New or used - what ever gets him the tools to learn CM, IPCC etc.
Thanks in advance.
Overall Rating: 4 (1 ratings)
Chawki Salhi Thu, 07/24/2008 - 02:12
Hi Baseer,
If you have the softwares (CCM and IPCC), you can install everything on VMWares. That is the best solution for a lab I think.
With best regards,
david.macias Sat, 07/26/2008 - 08:09
I think there is an old Cisco document from the 5.0 days which explains how to build a lab. Google for it and if you don't find it I can check my backups to see if I have it somewhere.
mymite060708 Wed, 09/10/2008 - 00:16
hi Chawki
Do you have the exact vmware requirements for ipcc 5? I keep getting hw is not supported
Chawki Salhi Wed, 09/10/2008 - 04:21
Yes I had the VM installed with this:
-Memory 2048
-hard disk: maximum size to 80Go
-2 virtual processors
Tell me if you need more info.
With best regards,
bobsairam Wed, 09/10/2008 - 05:59
Hi Chawki,
Where can i get the IPCCx 5.O image / evalaution version to install on VMware image for lab/ study
Chawki Salhi Wed, 09/10/2008 - 06:27
Hi Ranjan,
UCCX 5.0 can not be downloaded and must be ordered at Cisco. If you want to use it for demo purposes, you can buy it for around 100 euros if you are a Cisco partner and if I am not mistaking.
There is no evaluation version though.
