Gbic port unusable
Jul 23rd, 2008
error massage:
POST: Inline Power Controller Tests : Begin
POST: Found inline power controller write failure, inst 0
POST: Inline Power Controller Tests : End, Status Failed
Gbic port not functions.
why this happen coz of hardware or software?
lgijssel Wed, 07/23/2008 - 01:15
  • Red, 2250 points or more
Too bad; POST-failures are mostly hardware.
Leo
LUIGI PIETRONAVE Fri, 03/20/2009 - 14:59
I've got the same issue. To be more specific I found that i went into this issue only when, in a 3560-24P, i insert both sfp.
If i insert only one of them all is working fine
Had You any news ?
regards
Luigi
Leo Laohoo Sun, 03/22/2009 - 17:57
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
In enable mode, try the command "show post". The results should be "End, Status Passed". If the result comes back as "failed" then you need to RMA the switch.
