Qos to multiple sites
paris2london
I have the following requirement.
1. Each site (no PVCs) will get shaped to 128k. This is based on ACLs.
2. Within each shape Voice is to be given priority.
My config is as follows
class-map match-any L_QOS_CLASS
match access-group name L_QOS_ACL
class-map match-any E_QOS_CLASS
match access-group name E_QOS_ACL
class-map match-all SAT_VOICE_CLASS
match ip dscp ef
match access-group name VOICE_ACL
policy-map SAT_QOS_POLICY
class SAT_VOICE_CLASS
priority percent 33
class class-default
fair-queue
policy-map SAT_SHAPE_POLICY
class L_QOS_CLASS
shape average 128000
service-policy SAT_QOS_POLICY
class E_QOS_CLASS
What I am seeing is that shaping is working as it's supposed to, however when I issue a 'sh policy-map int s2/1' I get no matches on Voip traffic.
What am I missing?
lgijssel
Level 9
Level 9
The policy might not match the actual traffic pattern. Check that your voice traffic indeed has dscp value EF (46) and not 40.
Also check the setup of your QoS domain; the links between switches should trust their respective qos markings. The marking will be removed (0) when this is mot the case.
When trusting cos on the inbound links, verify that the cos-dscp map is correct i.e. maps cos5 to dscp 46. Also make sure that voice is set over a tagged vlan. Change the trust to dscp otherwise.
regards,
Leo
Hi Leo
I have checked that the voice packets on the remote end have infact EF set, and just to make sure I have added an additional access-list VOICE_ACL which specify the IP address of the Voip phone, however still no matches.
Your class map has an error:
match ip dscp ef
The match-clause should not be: match-all but: match-any.
regards,
Leo
Hi Leo
Thanks for that.
However I tried it and I still get the same result.
Any ideas?
