Two routing entry for same destination
Jul 23rd, 2008
Can anyone let me know what happen when there are two routes exist for same destination with same cost and AD and which route the device will install in it's routing table?
For example ,I am having the below two routes,
ip route 1.1.1.1 255.255.255.255 3.3.3.1
ip route 1.1.1.1 255.255.255.255 3.3.3.2
for the destination 1.1.1.1/32 which route will be preffered from this device and which will get installed in routing table?
i am thinking it will do default per-destination load balancing.please correct me if it is wrong.
Kmageshkumar Wed, 07/23/2008 - 04:22
Hi Leo,
Thanks for the Reply.Basically my Remote access VPN concentrator (1.1.1.1 for example) is reachable via two routes as per the above scenario,
I am not able to establish VPN from Desktop when both this routes as exists.please let me know why?
lgijssel Wed, 07/23/2008 - 04:31
Sorry, you are really providing too little information. It will not be possible to say anything about it without more knowledge about your network setup.
Leo
