Abdulbaseer Mohammed Wed, 07/23/2008 - 23:07
  • Silver, 250 points or more
Carlos,
Yes PG's do talk to AES via CVLAN. PG's can even get info from Avaya CMS.
Your Avaya team should be able to help you on AES configuration.
Make sure you check the versions and rev's for both AES and PG's.
Good luck,
Baseer.
c-pinilla Wed, 07/23/2008 - 23:31
Hi Basser,
I would like to know the maximun latency and the minimun bandwidth requiered by using a WAN connection between AES and PGs.
Thanks.
Carlos
