3750 Boot Loader
Jul 23rd, 2008
How do you transfer a bootable IOS to a switch from the bootloader switch: prompt? Documentation refers to copy command, but parameters only support flash file system reference. I had a corrupt image in flash, and was forced to delete it, and now the switch only boots to the boot loader prompt. Can I xmodem a new IOS? 3750-24 TS
colt45malt Thu, 08/28/2008 - 07:44
Yes, you should be able to xmodem a new IOS image over. It will take awhile to copy over as you might already know.
