Unity 5: Key Map to Verify Message Delete
Jul 23rd, 2008
  • Bronze, 100 points or more
I'm in the process of mapping the keys on Unity (version 5) to match how users interact with the current voicemail system. I have a request to try to replicate the delete functionality that users currently have. When a user goes to delete a message, they hit a 3 and are presented with a prompt that says "if you're sure you wish to delete this message press #." Is there a way to replicate this functionality on Unity? I tried poking around the Custom Key Map tool and I see I can set the delete key to be "3#," but this doesn't allow for the "are you sure..." message between the 3 and #. Anyone know if this is possible? Thanks in advance!
-Mike
http://cs-mars.blogspot.com
Rob Huffman Wed, 07/23/2008 - 06:19
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
