Multicast VPN issue
gregwoodson
I've got 2 core routers peered via BGP. I have deployed a Multicast VPN between them based on the following doc:
http://www.cisco.com/en/US/tech/tk828/tech_digest09186a00801a64a3.html
I actually see the multicast routes on all of the VRF's being broadcast from router to router and throughout the entire network. However, I am not able to see Multicast traffic passing. This is a very bizarre problem. Attached is the pertinent configs for the 2 routers.
Any ideas?
32 Replies 32
lee.reade
Level 4
Level 4
Assume you have no problems with ipv4 unicast between vpn sites?
Do you see the traffic pass through the core from PE to PE?
Does the mVPN tunnel interface come up?
Can you provide the following;
from PE
show ip pim vrf CustomerA interface
show ip mr vrf CustomerA
from CE
show ip pim interface
show ip mr
LR
No problems- traffic flows normally
regular traffic- yes- no problems, multicast traffic- I see the routes only- no multicast data
Yes it does- for both VRFs
Greg,
The control plane information looks good indeed. What do you use to generate the multicast stream? Can you check what TTL value you use when you generate these streams.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
The test program we are using has a ttl of 15. I am looking at the client that we are using as well.
The actual client and multicast server we are using for the application has a ttl of 128.
devang_etcom
Level 7
Level 7
What Multicasting mode are you running on your VRF connected routers? as I am not able to find any rp-address configuration under your vrf configuration.
regards
Devang Patel
I mean there should be entry of "ip pim vrf customerx rp-address" if you have PIM SPARSE MODE is running for the customer end.
Devang,
It should be fine as auto-rp is configured on Core router B:
ip pim vrf CustomerA send-rp-announce Loopback2 scope 16
ip pim vrf CustomerA send-rp-discovery Loopback2 scope 16
ip pim vrf CustomerB send-rp-announce Loopback1 scope 16
ip pim vrf CustomerB send-rp-discovery Loopback1 scope 16
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
How are verifying that traffic is not passing?
PEA has no cust vrf PIM neighbours, so the traffic will not flow end to end.
Can you verify that?
LR
Actually, PEA has several vrf PIM neighbors on both VRFs. I have confirmed that multicast traffic flows correctly within the individual PE's, but just not over the tunnel (even though the routing information shows up). I had rebooted both routers at one point, and when that occurred, multicast traffic was flowing over the tunnel, but unicast would not traverse the bgp connection at all. We had to break the tunnel by removing the mdt default statements. Once I put those statements back in, we see what we are seeing now. When the router first rebooted we saw unicast traffic trying to traverse thru the tunnel.
So both CE routers see PEA as the RP, via auto-rp?
show ip pim rp map
LR
Everything sees PEB (Core-2) as the RP via auto-rp- this is on both VRF's
Greg,
Could you please do a "show ip mroute count" for a specific s,g on the CE where you do have receivers. Could you also check that the RPF check is successful using "show ip rpf " on that same CE.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
CustomerB Site#sh ip mroute 239.195.0.0 count
IP Multicast Statistics
30 routes using 16838 bytes of memory
16 groups, 0.87 average sources per group
Forwarding Counts: Pkt Count/Pkts(neg(-) = Drops) per second/Avg Pkt Size/Kilobits per second
Other counts: Total/RPF failed/Other drops(OIF-null, rate-limit etc)
Group: 239.195.0.0, Source count: 4, Packets forwarded: 333727, Packets received: 333733
RP-tree: Forwarding: 0/0/0/0, Other: 0/0/0
Source: 10.0.36.254/32, Forwarding: 102371/1/486/5, Other: 102377/6/0
Source: 10.0.50.254/32, Forwarding: 39902/1/458/1, Other: 39902/0/0
Source: 192.168.253.252/32, Forwarding: 160692/1/494/2, Other: 160692/0/0
Source: 192.168.253.254/32, Forwarding: 30762/1/392/3, Other: 30762/0/0
CustomerB Site#sh ip rpf 10.0.50.254
RPF information for ? (10.0.50.254)
RPF interface: Multilink1
RPF neighbor: ? (192.168.252.1)
RPF route/mask: 10.0.50.0/24
RPF type: unicast (bgp 65502)
RPF recursion count: 2
Doing distance-preferred lookups across tables
CustomerB Site#
10.0.50.254 is a server broadcasting a multicast stream for CustomerB. Its information is not making it across the Tunnel, even though the route itself is.
