lee.reade Wed, 07/23/2008 - 06:54
Show ip arp should give you what you are looking for.
LR
Tarun Lohumi Wed, 07/23/2008 - 08:37
You will have to use the combination of the 'show arp' & the 'show mac-address-table address' command to find out what port is associated with what switchport.
Using the 'show arp | in 192.168.0.1' you can find the mac address for the device which has this IP.
Using the command 'show mac-address-table address ' you can find what port is this mac-address learnt on & hence the device connected on.
Hope that helps !!
