%DOT11-4-NO_SSID_VLAN but I put my ssid's in a vlan, didn't I?
Answered Question
Jul 23rd, 2008
Hey Everyone,
I've been googleing around for hours and I can't seem to find this error in my scenario. %DOT11-4-NO_SSID_VLAN
Crisco.com says that that means there are ssids that aren't assigned to a vlan, but I have specified a vlan in each ssid.
Here is my scenario,
We have 2 vlans at our office vlan 2 which is our office LAN and vlan 5 which is a guest vlan going straight to the internet. The access point is a 1240AG with the 12.4(10b)JA3 IOS.
Here is what I have so far:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2008.07.23 11:44:50 =~=~=~=~=~=~=~=~=~=~=~=
sho run
Building configuration...
Current configuration : 2706 bytes
version 12.4
no service pad
service password-encryption
hostname msp2prdwap03
enable secret xxx
no aaa new-model
ip domain name agostoinc.com
dot11 ssid agosto
vlan 2
authentication open
authentication key-management wpa
wpa-psk ascii 7 ---x--x-x-x-x-x-x-x-x-
dot11 ssid guest
vlan 5
authentication open
wpa-psk ascii 7 -x-x-x-x-x-x-x-x-x-x-x-
power inline negotiation prestandard source
username myuser password x-x-x-x-x-x-x-x-x
bridge irb
interface Dot11Radio0
description -- 802.11b/g Radio --
no ip address
no ip route-cache
station-role root
interface Dot11Radio0.2
description -- LAN --
encapsulation dot1Q 2 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.5
description -- Guest --
encapsulation dot1Q 5
no ip route-cache
bridge-group 5
bridge-group 5 subscriber-loop-control
bridge-group 5 block-unknown-source
no bridge-group 5 source-learning
no bridge-group 5 unicast-flooding
bridge-group 5 spanning-disabled
interface Dot11Radio1
description -- 802.11a Radio --
no ip address
no ip route-cache
shutdown
dfs band 3 block
channel dfs
station-role root
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
speed 100
full-duplex
interface FastEthernet0.2
description -- Agosto LAN --
no ip route-cache
bridge-group 1
interface FastEthernet0.5
no ip route-cache
bridge-group 5
interface BVI1
ip address 192.168.2.10 255.255.255.0
ip helper-address 192.168.2.254
no ip route-cache
interface BVI5
no ip address
no ip route-cache
ip default-gateway 192.168.2.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
logging synchronous
line vty 0 4
logging synchronous
login local
transport input ssh
end
Dot11Radio0 is reset, line protocol is down
I'm sure I'm missing one command or something dumb like that, any help would be greatly appreciated.
Dylan
Correct Answer by timsmith about 9 years 5 days ago
You don't have the SSID's applied to any radio's yet. If the radio has no SSID's associated to it, it will stay in reset mode.
In your dot11 radio 0 interface, you would need to setup your encryption mode, and apply your SSID's to be used on that radio.
Overall Rating: 5 (1 ratings)
Correct Answer
timsmith Wed, 07/23/2008 - 11:05
  • Cisco Employee,
Iain Goad Mon, 07/07/2014 - 04:00
Hi Guys, I have a similar problem IE
DOT11-4-NO_SSID_VLAN: No SSID with VLAN configured. Dot11Radio0 not started.
But my Vlan's are on Dot1 0, can you see from my config what I'm foing wrong?
[OK]
ADSLRouterWBG#
ADSLRouterWBG#
ADSLRouterWBG#sh run
Current configuration : 4573 bytes
version 12.4
no service pad
hostname ADSLRouterWBG
boot-start-marker
boot-end-marker
enable secret 5 $1$3tXO$tcAFKK9V0kzx3i8uwNAwu0
no aaa new-model
dot11 ssid Guest
   vlan 3
   authentication open
   mbssid guest-mode
   wpa-psk ascii 7 #############################
dot11 ssid Office
   vlan 2
   authentication open
   mbssid guest-mode
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.200 192.168.1.254
ip dhcp excluded-address 10.10.10.200 10.10.10.254
ip dhcp pool Office
   import all
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.254
   dns-server 8.8.8.8 8.8.8.4
ip dhcp pool Guest
   network 10.10.10.0 255.255.255.0
   default-router 10.10.10.254
ip domain name Goadsta.co.uk
username iain secret 5 $1$1oWr$TWISrtgzotX5Y7U3jQuFg0
bridge irb
interface ATM0
 no ip address
 no atm ilmi-keepalive
 dsl operating-mode auto
interface ATM0.1 point-to-point
 no snmp trap link-status
 pvc 0/38
  pppoe-client dial-pool-number 1
 switchport access vlan 2
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
 no ip address
 no ip route-cache cef
 no ip route-cache
 encryption vlan 2 mode ciphers aes-ccm tkip wep128
 encryption vlan 3 mode ciphers aes-ccm tkip wep128
 encryption mode ciphers tkip
 broadcast-key vlan 2 change 30
 broadcast-key vlan 3 change 30
 mbssid
 speed basic-1.0 basic-2.0 basic-5.5 basic-6.0 basic-9.0 basic-11.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
 station-role root
 antenna gain 0
interface Dot11Radio0.1
 encapsulation dot1Q 1 native
 no ip route-cache
 bridge-group 1
 no ip route-cache
 bridge-group 2
 bridge-group 2 subscriber-loop-control
 bridge-group 2 spanning-disabled
 bridge-group 2 block-unknown-source
 no bridge-group 2 source-learning
 no bridge-group 2 unicast-flooding
interface Dot11Radio0.3
 encapsulation dot1Q 3
 no ip route-cache
 bridge-group 3
 bridge-group 3 subscriber-loop-control
 bridge-group 3 spanning-disabled
 bridge-group 3 block-unknown-source
 no bridge-group 3 source-learning
 no bridge-group 3 unicast-flooding
interface Vlan1
 description $$FW_INSIDE$
 ip address 199.199.199.254 255.255.255.0
 ip nat inside
 ip virtual-reassembly
 ip tcp adjust-mss 1412
 bridge-group 1
interface Vlan2
 description $FW_INSIDE$
 ip address 192.168.1.254 255.255.255.0
 ip nat inside
 bridge-group 2
interface Vlan3
 description Wireless Guest
 ip address 10.10.10.254 255.255.255.0
 ip access-group 113 in
 ip nat inside
 bridge-group 3
interface Dialer0
 description $FW_OUTSIDE$
 ip address negotiated
 ip mtu 1452
 ip nat outside
 encapsulation ppp
 dialer pool 1
 dialer-group 1
 no cdp enable
 ppp authentication chap pap callin
 ppp chap hostname ##################
 ppp chap password 7 #################
 ppp pap sent-username ############## password 7 ##################
interface BVI1
 ip address 192.168.2.210 255.255.255.0
 no ip route-cache
ip route 0.0.0.0 0.0.0.0 Dialer0 permanent
no ip http server
ip nat inside source list 1 interface Dialer0 overload
access-list 1 remark Permit Interface Dialor overload
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 1 permit 10.10.10.0 0.0.0.255
access-list 113 deny   ip 10.10.10.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 113 permit ip any any
access-list 113 deny   ip any any
dialer-list 1 protocol ip permit
control-plane
bridge 1 route ip
line con 0
 no modem enable
line aux 0
line vty 0 4
 privilege level 15
 login local
 transport input ssh
scheduler max-task-time 5000
end
ADSLRouterWBG#
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
