Callmanager Licenses
jcsmith96
Can licenses for Callmanager 4.1 be migrated to 6.0
STEFAN CHRISTEN
Level 5
Level 5
If you upgrade on the same server using the DMA Tool, you can export the licenses after the upgrade on CUCM6.0 and register them.
If you want to install CUCM6.1 on another server you may get the licenses from licensing@cisco.com when you tell them the SO/PO numbers of the original orders.
Stefan
thanks
