ACE 4710 SSL server LB with stickiness
I will be replacing 11500 CSS which are not doing SSL termination, just load-balancing SSL sessions terminated on servers with ACE 4710.
On their CSS config, they were doing SSL-sticky. I understand the 4710 doesn't support SSL sticky, but can perform the same function by parsing the HTTP header. Has anyone done this config before and know where/how to parse the header to look for the SSL session# and stick connections to same server?
THANKS!
Syed Iftekhar Ahmed Wed, 07/23/2008 - 15:50
  • Blue, 1500 points or more
In Ace 2.x code GPP (Generic protocol parsing) was introduced that enables ACE to look into the Layer 4 payload.Which is how this stickiness id achieved.
details at
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/v3.00_A2/configuration/slb/guide/sticky.html#wp1133923
I dont think its currently available on ACE appliance yet.
Syed
