Joe Clarke Wed, 07/23/2008 - 09:46
Remove them from DCR. Go to Common Services > Device and Credentials > Device Management, and delete them from there. That will remove them from all LMS applications.
Joe Clarke Wed, 07/23/2008 - 10:00
Same location. Instead of clicking Delete, click Add, and input the details for the WLSE.
eliaspaulos Wed, 07/23/2008 - 10:07
thank you so much...no words how much you did help me!!! what management(standard, CNS,auto or
cluster? chose for WLSE. removing those may be helping me my inode/ out of space issue temporarily.once
eliaspaulos Wed, 07/23/2008 - 14:00
I have Add WLSE and remove AP's. so now how I should setup AP not to be found again? how I can block AP not to add on DCR. Thanks
duncalsi75 Wed, 09/10/2008 - 20:36
Hi jclarke
I have 41 devices that state in the Config Archive, they have failed to collect. I have 679 successfully connected devices. However when I click on the number of devices it brings a new window open showing 105 devices. I get the error
"SSH: Failed to establish SSH connection to xx.xx.xx.xx - Cause: Authentication failed on device 3 times. Failed to fetch config using RCP.Verify RCP is enabled or not. PRIMARY-STARTUP config Fetch Operation failed for TFTP. TELNET: Failed to establish TELNET connection to xx.xx.xx.xx - Cause: Authentication failed on device 3 times.
I have tried to remove them from Common Services, DFM and RME but they are not defined there. Is there a command line util I can use to delete items that are no longer on the network but installed in CiscoWorks. I am running LMS 3.0.1
Joe Clarke Wed, 09/10/2008 - 20:41
No. In order to clean up stale config archive failure entries, you need to run a database query. You will need to contact TAC to help you with this.
