CFNA to Huntgroup that contains forwarded line
Jul 23rd, 2008
Scenario:
With CUCM6.1(2)a Line (e.g. 200) has a CFNA to a Hunt Group (Huntpilot e.g. 100). The Hunt Group contains a Hunt List/Line Group with Broadcast Ringing and the members Line 200 and Line 201.
Issue/Problem:
If you call 200 and afer the CFNA Timer has expired, only Line 201 rings in the Hunt Group but not Line 200. If you call directly the Hunt Pilot 100 both Lines 200 and 201 ring.
Question:
In CUCM6.0 the issue was not seen. Has anybody had the same issue and found a solution (maybe some Service Parameter)? Does anybody know if this is a new "feature" or if it's a bug? I haven't found anything in the Release Notes or in the Bug Navigator.
Many thanks for your feedback
Stefan
