ASA Failover w/ EIGRP
Brian M
Does the ASA support EIGRP when failover is configured? My second appliance will not neighbor up with anyone when failover is configured.
6 Replies 6
steavg
Are you talking A/A or A/S...multiple context mode (A/A) does not support EIGRP.
Assuming you are using A/S EIGRP is supported.
Do you have a debug trace of your EIGRP on the ASA ?
Cheers
stefan
A/S with a pretty straight forward configuration using LAN failover and no state information. When I debug EIGRP PACKETS on the second ASA I don't get anything, it just sits. Here is the config:
interface GigabitEthernet0/0
speed 1000
duplex full
no nameif
no security-level
no ip address
interface GigabitEthernet0/0.3
vlan 3
nameif Outside
security-level 0
ip address 200.200.200.1 255.255.255.0 standby 200.200.200.2
interface GigabitEthernet0/1
speed 1000
duplex full
no nameif
no security-level
no ip address
interface GigabitEthernet0/1.252
vlan 252
nameif Inside
security-level 100
ip address 172.27.252.254 255.255.255.0 standby 172.27.252.253
interface GigabitEthernet0/2
speed 1000
duplex full
nameif DMZ
security-level 50
ip address 192.168.199.1 255.255.255.0 standby 192.168.199.2
interface GigabitEthernet0/3
description LAN Failover Interface
interface Management0/0
nameif Management
security-level 100
ip address 172.27.0.12 255.255.255.0
management-only
failover
failover lan unit secondary
failover lan interface failover GigabitEthernet0/3
failover key *****
failover interface ip failover 192.168.1.1 255.255.255.252 standby 192.168.1.2
router eigrp 16855
no auto-summary
network 172.27.0.15 255.255.255.255
network 172.27.252.0 255.255.255.0
network 192.168.199.1 255.255.255.255
passive-interface default
no passive-interface Inside
The 172.27.252.0 network is the one I need EIGRP running on
Brian,
Did you ever resolve your issue?
This is how it is documented by Cisco and I would like to know if anyone has done it this way. Thanks in advance.
!outside interface configuration
description outside interface connected to the Internet
nameif outside
security-level 0
ip address 100.10.10.1 255.255.255.0
!inside interface configuration
description interface connected to the internal network
nameif inside
security-level 100
ip address 10.10.10.1 255.255.255.0
!EIGRP authentication is configured on the inside interface
authentication key eigrp 10 cisco123 key-id 1
authentication mode eigrp 10 md5
!management interface configuration
nameif management
security-level 99
ip address 10.10.20.1 255.255.255.0 management-only
!EIGRP Configuration - the CLI configuration is very similar to the
!Cisco IOS router EIGRP configuration.
router eigrp 10
no auto-summary
eigrp router-id 10.10.10.1
network 10.10.10.0 255.255.255.0
!This is the static default gateway configuration
route outside 0.0.0.0 0.0.0.0 100.10.10.2 1
!Interface that connects to the Cisco ASA. Notice the EIGRP authentication paramenters.
interface FastEthernet0/0
ip address 10.10.10.2 255.255.255.0
ip authentication mode eigrp 10 md5
ip authentication key-chain eigrp 10 MYCHAIN
! EIGRP Configuration
router eigrp 10
network 10.10.10.0 0.0.0.255
network 10.20.20.0 0.0.0.255
network 172.18.124.0 0.0.0.255
network 192.168.10.0
no auto-summary
suschoud
Guys,
Saw this unresolved post today.....
Here you go :
Basically what is going on here is that when a pair of firewalls operates
asa failover pair they are regarded as a single device as far as the routed
path is concerned. The active is supposed to forward traffic and the standby
is supposed to wait until the active fails and then jump in and take over.If
the standby was to participate in the eigrp domain it would cause traffic to
be routed to it and then be dropped because it is not actively forwarding
traffic.
When an actual failover occurs the standby will become active and then begin
to participate in the eigrp domain. The IP addresses of the active firewall
remain constant through out the process and so from the perspective of our
internal eigrp routers the "firewall" missed a few hello messages and then
came back up.
But we can put the static route on primary firewall for the network from
where we want to monitor the secondary firewall. And that route will
replicate to secondary firewall as it is not a dynamic route and this will
help up us in accessing the secondary firewall for management purpose from
the inside subnets .
PLEASE RATE IF HELPS. :)
Sushil
francisco_1
Level 7
Level 7
Brian,
The mode you are using Active/standby does support EIGRP with version 8 software.
Is EIGRP working on the acive ASA? The standby peer is not forwarding any traffic when in standby mode and will not form any EIGRP neighbour relationship. Based on your config you are using active/standby in a routed mode. Only one ASA isactive and the active ASA can form EIGRP neighbour relationship.
If you need configuration help with EIGRP routing on the ASA, let us know.
Francisco.
vciric
http://www.cisco.com/en/US/docs/security/asa/asa84/configuration/guide/ha_overview.html
"In Version 8.4 and later, Stateful Failover  participates in dynamic routing protocols, like OSPF and EIGRP, so  routes that are learned through dynamic routing protocols on the active  unit are maintained in a Routing Information Base (RIB) table on the  standby unit. Upon a failover event, packets travel normally with  minimal disruption to traffic because the Active secondary ASA initially  has rules that mirror the primary ASA. Immediately after failover, the  re-convergence timer starts on the newly Active unit. Then the epoch  number for the RIB table increments. During re-convergence, OSPF and  EIGRP routes become updated with a new epoch number. Once the timer is  expired, stale route entries (determined by the epoch number) are  removed from the table. The RIB then contains the newest routing  protocol forwarding information on the newly Active unit."
