Layer 2 switch
Howard8777
Looking for a recommendation on a 24 and a 48 port Layer 2 switch that provides POE, 10/100/1000 and QOS. Any help would be appreciated
mrashby
Try the 3560-E series I worked with one in the past, they are pretty good. Here is an informational link.
http://www.cisco.com/en/US/products/ps7078/index.html
nick.franzen
Hi Howard,
I would recomend this tool: http://www.ciscowebtools.com/ProductAdvisor/child/1.0/switches.asp
It is the Cisco Product Advisor. It is very slick and easy to use. You are able to narrow down your switch choices by environment, form factor, topology, port density, system features, architecture, access port type and uplink connectivity.
Good Luck!
Nick
