07-23-2008 10:24 AM - edited 03-15-2019 12:09 PM
In field SRST Reference Name. Can I use the name same without DNS server?
Solved! Go to Solution.
07-23-2008 10:30 AM
without DNS your phones won't be able to reach the SRST router, either you add a DNS server or use IP address for reference
javalenc
if this helps, please rate
07-23-2008 10:31 AM
Yes, this is simply a descriptive name and is only locally significant. The IP Address field determines the SRST router that phones register with.
Hope this helps. If so, please rate the post.
Brandon
07-23-2008 10:30 AM
javalenc
07-23-2008 10:31 AM
Brandon
