CCM Download link
Jul 23rd, 2008
Does any one have the cisco link where I can download the direct upgrade patch from CCM 5.1.3 to 6.1.2.
I check eveywhere on CCO, but I could not
find it. All the links are from 6.0(1) to 6.1(2).
Please let me know.
Jaime Valencia Wed, 07/23/2008 - 10:28
  • Cisco Employee,
  • Hall of Fame,
    2011
you need to ask for the upgrade KIT, the upgrade file you're looking for is not available within CCO
javalenc
if this helps, please rate
Rob Huffman Wed, 07/23/2008 - 11:53
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Rohan,
I wondered where you went yesterday :)
There are no Downloadable files available to go from CCM 5.1(3) to CCM 6.1(2) You will have to use the Media you ordered to go from 5.1(3) to 6.0(x) and then use the files you downloaded to go from 6.0.(x) to 6.1(2) or just order the 5.1(3) to 6.1(2) Media via PUT.
Hope this helps!
Rob
rohanpatel Wed, 07/23/2008 - 14:28
Hi Rob,
I was trying to get the media through the cisco channel.
It was a waste of time. By the way, have you
upgraded call manager from 5 to 6. If so did you come across any issues after the upgrade
or do you know if I loose any setting after the upgrade.
Please let me know.
Rohan
