CAT OS to Native IOS
Jul 23rd, 2008
I am trying to upgrade my 6509-e boxes from hybrid to native ios.
The doc i have been following is below..
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008015bfa6.shtml#conv_32
I have uploaded the new os and set the config-register to 0X0 and saved the config. But when I try to reload the router i get the following error
Reload to the ROM monitor only allowed from console line
unless the configuration register boot bits are non-zero
Router#sh bootvar
BOOT variable = c6msfc2a-ipbase_wan-mz.122-18.SXF8.bin,1;
CONFIG_FILE variable =
BOOTLDR variable =
Configuration register is 0x2102 (will be 0x0 at next reload)
Router#sh run
Building configuration...
Current configuration : 452 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname Router
no aaa new-model
ip subnet-zero
redundancy
mode sso
boot system flash c6msfc2a-ipbase_wan-mz.122-18.SXF8.bin
interface Vlan1
ip address 30.0.0.3 255.0.0.0
ip classless
no ip http server
control-plane
dial-peer cor custom
line con 0
line vty 0 4
no cns aaa enable
end
Router#
wimccall Wed, 07/23/2008 - 20:46
Are you trying to reload with your confreg set to 0x0 from a telnet/ssh session?
If so, IOS is keeping you from doing something very bad: reloading the box and forcing it into ROMMON remotely (where you can no longer telnet or ssh into the box)
You will need to have a connection directly into the console port in order to do the conversion. Plus, if there is an issue, you really want to be there.
--William
