Slips on Gateway
Jul 23rd, 2008
How can I check my timing on the gateway or set it? Provider says the line looks good but the slips keep comming through.
kelvin.blair Wed, 07/23/2008 - 12:32
You can do a "show controller t1" on the router and see if you are getting slip errors. If so, issue the following command:
network-clock-participate wic X
network-clock-select 1 t1 X/X/X
I hope this helps.
michaeljbyrne Wed, 07/23/2008 - 13:01
I will give this a try thank you. I am assuming the X stands for interface and port numbers?
