Unity 5.0 Find-me
Jeffrey Knuckle
Does Unity 5 has a find-me feature? I.e. Caller call a single number, Unity/ccm rings internal IP phone, Mobile phone then external phone.
Chris Deren
This is available in Unity 7.0:
You can quickly modify your transfer settings through the voice user interface (VUI) or TUI so that calls are routed to you using predefined locations or calling party ID (CPID), also know as Follow Me.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps5745/ps2237/data_sheet_c78-478111.html
Unity Connection has had simialar feature for a while.
Also, check out CM 6.X Mobile Connect where you can configure remote desitnation to ring concurrently with your desk phone.
HTH,
Chris
Thanks for the reply.
We are still running 6.01 and Mobile Connect doesn't seem to work well, I've heard that it works alot better in later release.
After giving it some thought, I am going try the following, setup Unity to perform a supervisor transfer to a hunt group then have the hunt group (Sequentially) ring multiple locations.
Any ideas on how I could change Unity recording to say "Please wait while I try to locate your party" while performing a supervised transfer?
