annoying messages on my core
ougwuoke
The loggs below is from my core.. the port bening refered to is my route switch moudle. should i change the trunking mode to DOT1Q. It is currently on ISL
2008 Jul 23 15:52:19 PDT -07:00 %PRUNING-6-TRIGJOIN:trunk 15/1- send trig Join
2008 Jul 23 15:52:20 PDT -07:00 %PRUNING-6-TRIGJOIN:trunk 15/1- send trig Join
2008 Jul 23 15:52:21 PDT -07:00 %PRUNING-6-TRIGJOIN:trunk 15/1- send trig Join
2008 Jul 23 15:52:22 PDT -07:00 %PRUNING-6-TRIGJOIN:trunk 15/1- send trig Join
2008 Jul 23 15:52:23 PDT -07:00 %PRUNING-6-TRIGJOIN:trunk 15/1- send trig Join
2008 Jul 23 15:52:24 PDT -07:00 %PRUNING-6-TRIGJOIN:trunk 15/1- send trig Join
2008 Jul 23 15:52:25 PDT -07:00 %PRUNING-6-TRIGJOIN:trunk 15/1- send trig Join
6 Replies 6
Adam Frederick
Level 3
Level 3
This message indicates that a VTP pruning message is triggered on the trunk because of a VLAN status change; 15/1 is the module number/port number.
This message is provided for information only.
It appears you have your syslog level at 6 for VTP Pruning messages. I would simply just lower the level to 5 for these specific messages since they are only informational. Doing this will make them go away.
Issue the following configuration command:
Console> (enable) set logging level pruning 5 default
thank you for your help.. the info you provided helped
good idea but
shouldn't he move them to level 7 instead ?
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/6.x/configuration/guide/logging.html
Best Regards
Giuseppe
Thank you for the inform it helped
Giuseppe Larosa
port 15/1 is the port to MSFC and you have a Cat6509 in hybrid mode.
You probably have some Vlans that are defined on the L2 supervisor that haven't a L3 counterpart on your MSFC (an SVI VLan X)
so VTP is pruning the link 15/1 for these vlans.
This is the meaning of this message
for VTP on CatOS
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/6.x/configuration/guide/vtp.html#wp1021050
Hope to help
Giuseppe
