Module 6748 Catalyst
Jul 23rd, 2008
Dear All, How i ussualy use 6748 module in catalyst 6500. but i want to install it in 7600 router. how to make it layer 3 interface(routed port/real port). whats the different when this module implemented in 7600 router. is there any pro and cons using this 6748 module? or is it better to use SIP ? tx
Edison Ortiz Wed, 07/23/2008 - 18:05
  • Hall of Fame,
    Founding Member
Same as the 6500 switch:
interface gx/x
no switchport
ip address x.x.x.x y.y.y.y
You rely on the PFC QoS while with SIP, you can implement hierarchical QoS. I'm sure there are other differences but that's the only one that comes to mind w/o extensive searching :)
__
Edison.
Jerry Ye Wed, 07/23/2008 - 18:07
  • Cisco Employee,
Hi, the 6748 line cards will work and behave the same on the 7600's as the 6500's.
To make it work as L3 interfaces, issue the following interface level commands:
no switchport
no shut
If you are doing QoS, it is better off to use the SIP, because the 6700's does not support shaping.
HTH,
jerry
