Forced Authorization Code VS Client Matter Code
Answered Question
Hi all,
I have a client who wants to implement its existing user IDD password scheme when their users dials IDD calls.
7 + user IDD Password + Tel No + #
N.B: 7 is just a pre-dial digit in route pattern.
In this scenario, for the user IDD password, should i use Forced Authorization Code OR Client Matter code?? Is there any difference between the two??
Thanks!
Correct Answer by Jaime Valencia about 8 years 6 months ago
no, you're prompted for CMC or FAC after you dial, not before or in between
javalenc
if this helps, please rate
Overall Rating: 5 (1 ratings)
Jaime Valencia Wed, 07/23/2008 - 18:54
FAC is more related to groups of users and privileges to do certain calls (LD, international, etc)
CMC is used to identify calls per user
the way they work is that you dial the number, and then you're prompted for FAC, CMC or both in the order mentioned
javalenc
Jaime Valencia Fri, 07/25/2008 - 18:30
it's really up to you. if you need per user codes then use CMC, if it's going to be per group then use FAC
if you do not type in the FAC or CMC call won't go thru
you need to add the CMCs and then enable the route patterns to use them
javalenc
Correct Answer
Jaime Valencia Sun, 07/27/2008 - 19:16
javalenc
