BGP peer and VRRP
Answered Question
Jul 24th, 2008
R1
S
R2 R3
R1 R2 and R3 are on same switch (network) running BGP, R2 and R3 are running VRRP,
My quest is that should R1 make peer with VRRP address or should R1 make peering with both R2 and R3 real addresses.
I just saw some customer configuration making R1 peering with real addresses as well as VRRP address, that makes me confuse that what could be reason of configuring like this.
Umair
Correct Answer by Harold Ritter about 8 years 10 months ago
Umair,
That is correct. R1 should peer to R2 and R3 physical address so that both session could be up at the same time.
Overall Rating: 5 (1 ratings)
lee.reade Thu, 07/24/2008 - 00:37
  • Silver, 250 points or more
R1 must peer with the R2 and R3 real addresses.
The TCP session between the two hosts would not get established if R1 tried to peer with the vrrp address, as R2 and R3 would be sourcing their TCP sessions from their real ip address.
LR
Harold Ritter Thu, 07/24/2008 - 13:52
  • Cisco Employee,
Lee,
The session will come up assuming that R1 initiates the session, in which case the router being the primary would reply with the VRRP virtual address rather than the physical address.
The TCP session would obviously need to be reestablished if a VRRP failover takes place.
sdoremus33 Sat, 07/26/2008 - 16:29
  • Bronze, 100 points or more
Original Q: quest is that should R1 make peer with VRRP address or should R1 make peering with both R2 and R3 real addresses
Yes you need to peer with bothe the pysical active and physical standby in order for VRRP to function
Harold Ritter Sat, 07/26/2008 - 17:41
  • Cisco Employee,
Steven,
I don't see any advantage to use VRRP in this context. VRRP is something that would be used to provide redundancy on a user subnet. Why use VRRP if you have BGP sessions from R1 to both R2 and R3.
sdoremus33 Sat, 07/26/2008 - 18:16
I agree, however I was just answering the initial question as to VRRP peering with both routers
syedumairali Mon, 07/28/2008 - 01:23
VRRP is running because their are some hosts sits on that network connected to switch where BGP is running.
SO what I get from the above thread is R1 must make peers with R2 and R3 Real address but not VRRP address ? right ????
Umair
Correct Answer
Harold Ritter Mon, 07/28/2008 - 04:55
  • Cisco Employee,
Umair,
