Cisco 1801/k9 + NAT on the FE0 WAN interface
Jul 24th, 2008
I have recently gotten a new 1801 to use at Home to terminate my cable broadband but I cannot seem to get the PCs connected to the switch ports to access the internet.
The NAT configuration I have done is:
WAN interface:
interface FastEthernet0
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
VLAN interface for the switch:
interface Vlan1
description OLD PRIMARY VLAN
ip address
ip nat inside
ip tcp adjust-mss 1452
NAT config:
ip nat pool NAT_POOL_OLD netmask
ip nat inside source list 1 pool NAT_POOL_OLD overload
access-list 1 permit
access-list 1 deny any
Can you see any issues with my NAT config that would stop my users accessing the internet?
I've attached my running config for more info.
Can anyone offer any help?
a.alekseev Thu, 07/24/2008 - 04:29
no ip nat pool NAT_POOL_OLD netmask
no ip nat inside source list 1 pool NAT_POOL_OLD overload
no access-list 1
access-list 1 deny host
ip nat inside source list 1 interface FastEthernet0 overload
twhittle1 Thu, 07/24/2008 - 04:38
Thanks A lot, I have made the changes and I will take it home tonight and try it out.
twhittle1 Thu, 07/24/2008 - 10:53
Hi, This didn't work for me, I was trying to figure it out myself and I messed up. So I reloaded the router here is the new config. Can anyone advise what I am missing to get my internet connection working? I have a cable modem attached to the fa0 and a laptop connected to a switch port. I have gotten the Router to assign a DHCP address but I get no action from the internet. Can anyone advise??
a.alekseev Thu, 07/24/2008 - 10:59
did you get ip address from dhcp srerver for fastethernet0?
sh ip int brief
twhittle1 Thu, 07/24/2008 - 14:28
Hi, no I didn't it says unassigned. What could this mean?
Am I missing a configuration command or is my provider not doing something?
sirdudesly Thu, 07/24/2008 - 17:21
I use an 1803 to terminate my cable modem at home and it works perfectly, when I get home i'll post the interface config.
I use mine with telstra bigpond 30/1 cable with a motorolla surfboard.
twhittle1 Thu, 07/24/2008 - 22:24
Output of my show int fa 0 is:
show int fa 0
FastEthernet0 is up, line protocol is up
Hardware is PQ3_TSEC, address is 001d.70f9.b77e (bia 001d.70f9.b77e)
Internet address will be negotiated using DHCP
MTU 1500 bytes, BW 10000 Kbit/sec, DLY 1000 usec,
Keepalive set (10 sec)
Half-duplex, 10Mb/s, 100BaseTX/FX
Last input never, output 00:00:02, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
38 packets output, 8474 bytes, 0 underruns
0 unknown protocol drops
0 lost carrier, 0 no carrier
Any ideas? It doesn't lok like its getting an address via dhcp. Am I missing some config? The Int fa 0 config is:
ip address dhcp
ip nat inside
duplex auto
speed auto
thats it.
Thanks for your help!
twhittle1 Fri, 07/25/2008 - 07:00
Hi Guys
I have been through a bit old config refresh.
I have managed to get my dhcp to work buy adding the ip dhcp client client-ID fa 0
Command but I still cant access the internet :( I will check what cable modem I have when I get home.
My Show run as it stands is attached. I know the FA0 is shutn down but thats not the prob because I only have that while I'm at work.
If anyone can sugegst why its not working that would be great.
Sirdudley are you able to post your config so i can compare?
