MGCP Dial-peer question
Jul 24th, 2008
Set up - MGCP GW connecting to either the Telco or TDM PABX,
Can someone confirm if you use MGCP on a GW that you still need a single Dial-Peer voice POTS with service mgcpapp configured pointing either to the PSTN or other TDM system. I thought when using MGCP you do not need Dial-Peers or is the dial-peer / service mgcpapp needed to route call calls from the PORT to the CCM telling the port is controlled by CCM
joergwesely Thu, 07/24/2008 - 07:20
When using E1 or T1, you don't have Dial-peers. What you do is tell the controller to be "remote controlled" by mgcp, like this:
controller E1 0/0/0
pri-group timeslots 1-31 service mgcp
When using SRST, you need to configure dial-peers that take over when the connection to the CCM breaks.
iptuser55 Thu, 07/24/2008 - 07:37
Thanks that is what I thought but others have told me to add a voice pots 99901 and use the MGCPAPP commend on the dial-peer
Jaime Valencia Thu, 07/24/2008 - 08:23
usually you configure the dial-peers for analog interfaces controlled by MGCP but you can also create one for digital interfaces, it's not mandatory to create it
if this helps, please rate
