Cisco SUP-720-3B Compact Flash OIR Support
Jul 24th, 2008
Running native. OIR supported for compact flash?
I suspected it would be without problems, however, after upgrading to 1GB ExtremeIII (SanDisk), dir slot: returns no such device. Next show file system I have an '*' size field is empty.
* - - disk rw disk0:
Used same flash on another 65K pair no problem - so i'm pos mem is good.
Reload could be in order?
tstanik Wed, 07/30/2008 - 14:39
I think, that before removing SAMI card, you will either need to power it down first using CLI, or press the button on the card for the same effect (Wait for the light change after that).
